• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    tommy.bus
    Properties and Quick Properties not displaying information for objects
    344 Views, 3 Replies
    07-10-2012 12:23 PM
    So here's the problem.  When I select any object, my quick properties tab is blank and my properties tab doesn't register anything.  Also, I get an error message when I go into my CUI to try to modify the quick properties tab.   Pretty frustrating. I've attached a couple of images for reference.  I've repaired, re-installed and unistalled and re-installed and still have the same probelm.  Please help!!
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @2.8GHz
    ATI FIrePRo V5800 (FireGL V)
    12 GB Ram
    64 BIt OS
    Please use plain text.
    pendean
    Re: Properties and Quick Properties not displaying information for objects
    07-10-2012 02:50 PM in reply to: tommy.bus
    A Windows Registry Cleaner (or a Windows Registry error) took place on your PC: a repair reinstall of AutoCAD is the sure fix for the Prop and QP issues.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Contributor
    tommy.bus
    07-10-2012 09:53 PM in reply to: tommy.bus
    I ran the repair and the re-install today and neither fixed the issue.  Before I left work, I completely unistalled everything Autocad from my system, including the registry, and set it to reinstall.  I'm really hoping that will fix it....
    12 GB Ram
    64 BIt OS
    Active Contributor
    tommy.bus
    07-11-2012 06:44 AM in reply to: tommy.bus
    Well, I got into work this morning and my properties and quick properties pallettes are fixed.  Just a note for anyone having this problem.  When I unistalled through control panel and re-installed, it did not work.  I had to follow the instructions from this link to get it to work:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    12 GB Ram
    64 BIt OS
