AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Profile not staying current
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HELP!! I am in a constant state of frustration with this profile mess. I have read previous posts about setting the Target in the shortcut link, however, this is not working for me.
I am using AutoCAD 2012. The shortcut is on my taskbar. I recently added an update that AutoDesk sent as I was having errors of some kind.
I right click on the icon>Properties> set target to "C:\Program Files\Autodesk\AutoCAD 2012 - English\acad.exe" /p profilename. Is the profile name case sensitive? I have even reset the shortcut and that didn't work either.
I reopen AutoCAD and the profile settings are missing (i.e. look, support paths, etc)
I have set up the profile and exported it out to MyDocuments. When I restart AutoCAD it says there is no profile by that name and it's going to use the default setting. WTH?!?!
I have even deleted all the profiles from the support folder to see if that would reset it and it doesn't. I've been using this setup since 2012 was rolled out and haven't had any issues until now.
Can anyone help me?
Mary
Re: Profile not staying current
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I am saving to Options>Profiles first. Then exporting to My Documents folder.
I figured out that the Inventor plug-in was causing the issue. I uninstalled this, deleted the "fixedprofile.aws" file and reset the Target.
this seemed to work. I had to do a couple tweaks to my profile but overall, it's been retaining the path and profile.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Am I understanding correctly that you are trying to start up AutoCAD using a shortcut which points to an exported profile (*.arg)? If so, please take a look at the following technical support document: http://usa.autodesk.com/getdoc/id=TS17887. Be sure to use quotes for the path and the file extension as noted in the document. One other item to be aware of is that if the profile name already exists in AutoCAD, AutoCAD will bypass the profile used in the shortcut path. In other words, you may want to delete or rename the existing profile and then launch AutoCAD using the profile with your desired settings.
Please let me know if this helps.
Cheers!
Volker
Volker Cocco
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
THis doesn't help.
what happens to me is 2012 opens up in Autocad Classic mode but no menu toolbars are showing.
I cahnge it to Basic 3D and then back to Autocad Classic and the default toolbars pop up, not my previously loaded menu.
Is this addressed in a service pack? this is the first version I've had this issue with, along with other bugs....
