• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Problems with plotting on larger paper size and "plot transparency"
    135 Views, 3 Replies
    02-04-2013 11:02 AM
    Hi I have a canon ipf605 plotter. I try to plot to a custom paper size with the "plot transparency" and it doesn't work. Any ideas why not?
    Please use plain text.
    Re: Problems with plotting on larger paper size and "plot transparency&quot
    02-05-2013 01:37 PM in reply to: mouke
    >> it doesn't work
    ...means what? Plotter does not get data, your workstation crashes, your server crashes, plotter gets data but shows an error message, ...?
    Generally, plotting with transparency on means a lot more memory to be used. So I guess your plotter has not enough memory for processing the data. It may help to:
    • try to find an option in the driver named like "process on computer"
    • plot to file and send then the file to the plotter
    • plot to DWF and then print the DWF from DesignReview to the plotter
    Good luck, - alfred -
    Alfred NESWADBA
    New Member
    02-11-2013 09:52 PM in reply to: alfred.neswadba
    dear alfred, thanks for your replay at first let me explain, "doesn't work" means that i can see the printout on the preview but it doesn't print . That happens with every custom paper i tried to plot with "print transparency" (it works ok with the iso papers etc) It could be lack of memory but why it works with the standard size papers?
    02-12-2013 01:31 AM in reply to: mouke
    I don't know what custom sizes you tried, if they are all bigger than the default sizes then it's a memory problem.
    I would come back the "try to plot to DWF (or PDF)", if that works, use DesignReview (or Adobe Reader) to send it to the plotter ==> now again the question, does that work?
    - alfred -
    Alfred NESWADBA
