• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    maurizio.dondo
    Problem with selection objects in a large zone PART 2 (for luconceicao)
    106 Views, 3 Replies
    01-31-2012 01:26 AM
    I you joint an example of file with two targets of selection (1 and 2). The objects to be selected are exactly in the middle of these two targets, but select the objects without using the targets. Example command are Move : zoom in, click for first point (Target 1), zoom out for easy pan, and zoom in again for the second click (Target 2). All the objets out of windows are forget.
    The Targets are an example and do not exist really.
    Autocad functioned perfectly before several version. Why this serious change ?
    Thank you for your assistance
    Best regards
    Please use plain text.
    Product Support
    Re: Problem with selection objects in a large zone PART 2 (for luconceicao)
    01-31-2012 06:55 AM in reply to: maurizio.dondo
    Thanks, I will have a look.
    But hey! Everybody can help, too :smileyhappy:
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Autodesk, Inc.
    Product Support
    01-31-2012 07:32 AM in reply to: maurizio.dondo
    Hi Maurizio,
    I can reproduce the issue.
    Our developers are aware of it, it seems like the selection is screen based.
    I am sorry but I can't tell you when it is going to be addressed but if this is very impacting to you, you can submit your product feedback via this page:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Cheers,
    Luciane
    Active Member
    maurizio.dondo
    02-01-2012 12:03 AM in reply to: luconceicao
    Hi Luciane,
    Thank you nevertheless of your assistance. I indeed will write at this address to see what they will do. But i think nothing.
    Still thank you very much and see you soon
    Maurizio
