• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    yarnstormer
    Problem plotting to pdf - my tif file is green!
    223 Views, 3 Replies
    09-20-2012 10:07 AM
    I'm working in civil 3d - plotting paperspace drawings with tif files and linework etc in the model space.
    My tif files should be showing up light gray - and they are onscreen and in the plot preview AND when I plot to my plotter. But, when I try to plot to a pdf the gray areas are a dark green.
    I'm running adobe pro 9.0
    I can start a new file, insert one of the same tif files and plot normally so it's something to do with this drawing.
    The drawing has 26 paperspace sheets (and 26 x-ref tif files) so I hesitate to just wblock it out or something obvious like that. I am hoping someone will know of a setting I may have changed by mistake. I have had this drawing crash a couple of times.
    Any suggestions?
    Please use plain text.
    Active Member
    yarnstormer
    Re: Problem plotting to pdf - my tif file is green!
    09-20-2012 10:55 AM in reply to: yarnstormer
    See the green? Supposed to be gray....
    Active Member
    yarnstormer
    09-20-2012 11:25 AM in reply to: yarnstormer
    hm...changed background to "on" in the properties and that seems to have fixed it for now...
    Member
    10-18-2012 08:20 AM in reply to: yarnstormer
    I had the same issue.
    I wish I knew what changed because I opened an old file that used to work perfectly in the same software, and had this issue.
    Maybe an Adobe upgrade issue??
    I changed the image's Background Transparency to "Yes"; and that fixed my problem.
