• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    gobi.kastelic
    Plotting an airfoil in AutoCad 2012
    1522 Views, 12 Replies
    01-15-2012 02:22 PM
    Hi
    I just downloaded AutoCad so I am very unfamiliar with it but I do need so help witha particular problem.  I need to be able to import the airfoil geometry of a NACA 2412 airfoil.  I know how to get the XY coordinates but I don't know how to import these points (as a .txt file?) into ACAD.  What function would I use?  Spline?  If so how do I get it to draw all the points I have?  I need to then extrude the shape to be able to mill airfoil sections...that part I can figure out....just need to import the points to get a nice curve.
    Thanks for any (and quick :smileyhappy: ) help!
    Please use plain text.
    Patchy
    Re: Plotting an airfoil in AutoCad 2012
    01-15-2012 09:17 PM in reply to: gobi.kastelic
    Very easy.
    Open that .txt file, highlight the coordinates and CTRL+C
    Go to autocad, type in Spline or Pline command, when it prompts for first point, right click and Paste.
    New Member
    gobi.kastelic
    01-15-2012 09:52 PM in reply to: Patchy
    Ok, got it to plot  a good looking airfoil.  Is there a way to scale the airfoil?  Right now it is at an inch long, I'd like it to go to 6 inches while keeping the same shape - is this even possible since I input discrete numbers for each point on the curves?
    Patchy
    01-15-2012 10:17 PM in reply to: gobi.kastelic
    Snap a picture or attach your drawing here, I don't want to lead you the wrong way.
    New Member
    01-28-2013 06:56 PM in reply to: gobi.kastelic
    i am attaching the coordinates file ......please tell me how to draw in cad with correct dimensions
    New Member
    01-28-2013 06:58 PM in reply to: kick507
    this is diagram of airfoil.
    Patchy
    01-28-2013 11:28 PM in reply to: kick507
    Put texts in the correct format as shown, then command SPLINE, when it prompts for starting point, Paste the texts in.
    Active Contributor
    LaserGuy
    01-29-2013 06:52 AM in reply to: Patchy
    +1, and my 2 cents
    Dell T7500
    x5690 Xeon 3.46/3.73GHz
    24Gb, SSDs, Quadro, Win7 x64
    AutoCAD Mechanical 2014
    Member
    02-08-2013 12:24 PM in reply to: LaserGuy
    I am in the same situation as the previous post. I have created my airfoil, but I would like to set it to 160 cm, How do I resize the object to scale this new dimension.
    I have the image I created in order to understand where I am at currently.
    JM
    Member
    02-09-2013 04:10 AM in reply to: jemo07
    Hi again, also, when I try to do to a dimension, I can do it for just about anuthing, but not for a Spline, like the airfoil, How do I manage that also?
    Thank you all in advance,
    JM
