• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Plotting PDF underlay
    675 Views, 1 Replies
    07-20-2011 11:30 AM
    Whenever I plot to PDF (using DWG to PDF.pc3) PDF underlays in the drawing appear faded in the resulting PDF. If I plot from the same file in acad 2011 the PDF underlays appear normal. Any ideas?
    Contrast for the PDF underlay is set to 100 and fade is set to 0.
    Please use plain text.
    Product Support
    Re: Plotting PDF underlay
    07-22-2011 06:37 AM in reply to: ppauerthd
    I am not sure I understand your question.
    Do you already have a PDF underlay when you create a new PDF?
    Can you send a sample file with the steps to reproduce?
    Are you using the same plot style configuration in 2011 and 2012?
    Cheers,
    Luciane
