• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    GrantsPirate
    Re: Playing with solids and need help
    10-13-2011 07:33 AM in reply to: KansasCAD
    There is a Mode setting in Loft, the mode choices are surface or solid, in 2012 at least.
    Start the command, look at the command line or in using DYN press the down arrow key, pick MO or type MO, finally specify solid.
    Please use plain text.
    Distinguished Contributor
    10-13-2011 07:50 AM in reply to: GrantsPirate
    Excellent, Thank you so much for the help.
    Daryl
    10-13-2011 09:26 AM in reply to: KansasCAD
    An easier method might have been to line up the corners of the two solids and then solidedit intersect to get the corner.
    Then  simply presspull the lengths.  No loft required.
    Inventor Professional 2014 Edu 64-bit
