AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Playing with solids and need help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am new to doing anything with solids and 3d in AutoCAD. I have had Years of Civil 3D and Land Desktop but never had the need to get into doing solid modeling.
This is a transition box between two precast concrete culverts. I am having trouble with an inside fillet (it strengthens the box). See picture.
What is the best way to fill in this area? When I get it filled in I plan to merge them togther into one solid.
Daryl
Re: Playing with solids and need help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Like this?
From the Land of OZ
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yea for what I am doing that would probably work. In reality it will probably be more like a chamfer. (Both bottom edges being extended until they intersect. Is that possible?
Thanks for the fast reply.
Daryl
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, like this
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, exactly like that. Now can you explain how I can do that? Remember that I am new at this and I normally only use Civil 3D. The help that they tried to improve really stinks in this new 2012 version of Civil 3D. Very hard to get to help on plain AutoCAD.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not that difficult, you draw the base where they are going to fillet, make it a polyline; then put a node at the top.
Use command LOFT, select the base then the point. That's all.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got it done but it created a Surface (Loft). Can that be converted to a solid so I can merge it with the other two pieces of the chamfer? I want to merge them so I can get a total volume when I get finished.
Daryl
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Union command will glue them together.
Massprop command will list the volume.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It doesn't seem to work for me. here is the drawing. It is in 2012, I hope that is OK. If not let me know and I will try to save it back.
Thanks again for all of your help.
Daryl
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Type in Region, select the base polyline, then loft.
