• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Re: Paragraph Spacing in MText (AutoCAD Architecture 2011 as AutoCAD 2011)
    11-02-2010 01:32 PM in reply to: apxby
    I have the same problem.  I got it to work somewhat by using 9" text and setting the spacing to 4" above and below the next paragraph.  I also got it to work by using 4" text with the same settings above and then scaled the text up to 9".  It automatically increased the 4" spacing to a larger value.  It is a clumsy work around but it works.
    Ells
    Please use plain text.
    Active Contributor
    11-03-2010 11:05 AM in reply to: stanmpd
    I got this to work in a round about way with v2011.  I used 1" text and since I wanted the space between paragraphs to be 1-1/2 the text size is set that to 1-1/2".  The text size I want is 9" so I went to "Annotation" on the ribbon bar and selected scale text and scaled it to 9".  Attached is the end result.  This is a clumsy fix.
    Ells
    Active Contributor
    11-03-2010 11:48 AM in reply to: ejenkins
    Works great, unless you use Annotative Text.  This will help in model space though, thanks
