• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    PROBLEM WITH LABELING IN PAPER SPACE. DIMENSIONS WAYYYY OFF
    143 Views, 5 Replies
    06-18-2012 01:44 PM
    We do a lot of labeling in paper space and have been encountering a problem with our dimension command mislabeling lengths and widths.  Please see attached DWG.  The road width should be 24' and its labeling it 880'.  BUT measuring hoizontally it seemed to work fine.  Really strange.
    I am using the dimension command and snapping nearest and perpendicular.  If I just click without using osnap it seems to work.
    .  We tried using the DIM   /   DIMFLAC   /   V     /   and selectiong viewport
    The funny thing is that I dont have this problem with every drawing.  Just some seem to have this glitch.
    Any ideas would be great!!!
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: PROBLEM WITH LABELING IN PAPER SPACE. DIMENSIONS WAYYYY OFF
    06-18-2012 02:13 PM in reply to: knisewonger
    This is why
    Member
    06-19-2012 05:08 AM in reply to: knisewonger
    When I change the scale from 1 to 40 and vise versa it either messes up my vertical or horizontal measurements.  Is there a way to make it to where both my horizontal and vertical scales will work?
    *Expert Elite*
    3wood
    You can automatically load STARTUPCHECK.vlx into your AutoCAD at startup to check the mismatched-scale dimensions and fix them.
    3wood
    CAD KITS
    Member
    06-19-2012 05:14 AM in reply to: knisewonger
    Here is an example of a drawing that both horizontal and verticle dimensioning works.  I cant seem to figure out why they are different.
    *Pro
    nestly
    06-19-2012 05:33 AM in reply to: knisewonger
    The dimensions are using two different Dimension Styles;  Henkels, and Henkels <style overrides>
    Type "D" to enter the Dimension Style Manager, set Henkels current then use MatchProperties to fix the dimensions that have the 40x DIMLFAC override.
