• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    PDF Printing Issue - Drawing Rotation
    305 Views, 2 Replies
    12-08-2011 11:36 AM
    I'm going to try and explain this the best I can.
    We recently upgraded computers and upgraded to autocad LT 2012.  We used to use autocad LT 2011.  With the only system I used acrobat X standard to print pdf's.  I'm using the same program with the new system/version of autocad.
    It used to be that when I was at the standard autocad plot dialog box under "Drawing Orientation" I could select Portrait or Landscape.  When I did the is the litte prview box with the paper size would rotate and the drawing rotate with it.  So if I changed the orientation to landscape the drawing would plot to pdf correctly.
    Now when I change the orientation the paper changes in the preview but the actual drawing doesn't rotate to fit the page orientation.  I'm not sure if that makes sense or not.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: PDF Printing Issue - Drawing Rotation
    12-09-2011 04:40 AM in reply to: arkman
    Are you sure 2011 did not have a custom PC3 file that you need to copy over and use in 2012?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Active Contributor
    12-09-2011 06:31 AM in reply to: arkman
    I'm fairly certain there wasn't one.  The only person in the office that could do thta is me, and I don't ever remember doing it.
