AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The icons on my osnap toolbar do not coincide with the commands. Any quick fixes??
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure If I understand your problem
OSNAP are not commands as such. When selecting an OSNAP Icon
it is expecting you to select an objects snap points. IE EndPoint, Mid Point,
Intersection, Center, Quadrant, Nearest, Tangent, Perpendicular, Node. etc.
Hope this helps
Ron
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Ron for the quick response.
When I hover over any one of the icons, the discription window that opens does not match. For instance, hovering over the "center" icon gives me "snap to quadrant". The same is true with every icon on that toolbar. I have not experienced this with any other toolbar.
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is a wild suggestion. Did you change the font size in your windows to make the font larger. If yes, set the font size back to 100% and check.
Re: Osnap toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks all for the suggestions. I checked CUI and everthing looked fine. Selected 'NODE' to look specifically at it and everything appeared fine. Applied it to the 'node' icon, even though it was already assigned, then hit apply at the bottom of the screen. Toolbar corrected. Don't understand, but it worked.
