AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Opening multiple DWGS, always opens a new applicatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i have architectural desktop 2007 installed with windows 7 and i have the same problem
my taskbar and sdi are set to "0"
in windows 7 explorer does not have "tools" or at least i cant fnd it
i found my folders options but when i pick what program to open dwg files i only see autocad.exe
where do i find the autocad launcher? what is the file name?
thank you for your help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi, thanks for the help!
the directory acshellex does not exist and the file aclauncher.exe does not exist on my computer?
i even looked in my old 2006 disk since the double click worked there but i couldnt find aclauncher on the cd either?
i was reading another post talking about how the only way to edit dde in the registry and how they control how file types open in windows 7 is with an application called "file type doctor"???
ive read a couple of different methods on how to fix this but i dont seem to have those tabs, directories or files? is this a windows 7 thing? or because im running autocad in "administrator mode" since its got compatability issues with windows 7?
thanks
for your help!
dan
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's my question...... Why?..... I think the launcher only appeared once I installed Trueview but I could be wrong... But why does the "AUTOCAD Application" not work.. Now you have to Check SDI, Taskbar and mess with Windows folders options and the associated launcher applications, Before u just ran Single or multiple dwg mode... I thought it was supposed to get easier with upgrades... and to add to it all SDI is not in the user documentation or in the System variables. I remembered it from a while back but could not remember the name... Aggggh very annoying... Sorry had to go on a rant.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oh BTW thx the solution worked for me also.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank u very much!!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For me, I had to go to Control Panel: Programs: Default Programs: Set Associations, and then I scrolled down to dwg, selected it and hit 'Change program...' at the top. Evidently when I installed the Inventor trial version on my computer it changed my setting from AutoCAD DWG Launcher to AutoCAD Application, so I changed it back. That's it!
