AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Opening multiple DWGS, always opens a new applicatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just got AutoCAD 2010, its not bad but has a issue that bugs me.
If i have one file open, and go to my desktop (or any folder) and double click a file to open it... it opens the new drawing in another instance of AutoCAD. Id rather have it open in the same instance to ease of use and so it wont tie up mulitiple network licenses.
Can someone help?
Re: Opening multiple DWGS, always opens a new applicatio n
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Instead of going to desktop, use yellow folder on menubar to open more dwgs.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
no, id rather not do it that way. I get DWGs emailed to me and i would rather double click inside of Outlook instead of saving it somewhere then going into AutoCAD and finding it thru the open command.
AutoCAD 2009 would let me do it the way i want to...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is your SDI system variable set to 0?
Is your Taskbar system variable set to 0?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
im not really sure what those are. haha
But ill try to find them and look em up.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Keep in mind some third party software will change your settings to disallow opening more than one file per instance of autocad and will either close the existing drawing before opening the intended drawing, or open another instance.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Type SDI then enter on the command line you should get the following command line response. Enter new value for SDI <0>: If your value is <1> type in 0 and then hit enter.
do the same with taskbar. Type in TASKBAR then enter on the command line you should get the follwoing command line response. Enter new value for Taskbar <0>: If your value is <1> type in 0 and then hit enter.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok i set everything to 0 and it still opens multiple ACAD applications.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In Windows Explorer select Tools then Folder Options. On the File Types tab find DWG in the list and make sure it is set to open with AutoCAD DWG Launcher and not acad.exe
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you very much M Hensley, that fixed it!
