• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    amahjoub
    Opening a drawing done in a student version in a licensed version.
    346 Views, 6 Replies
    01-18-2012 10:46 AM
    I would like to give someone some of my drawings to someone who has a licensed version of autocad. but when they open the work i have done on my student version it still has the tags saying "autodesk educational version" . even when i copy it to a new drawing in the licenced version it still has the educational versions.....can anyone help? Iv tried downloading a trial version of autocad to open the file but it knows that Iam a student...just basicly want to do some drawing in the trail version so i can hand the drawing over to a friend....
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Opening a drawing done in a student version in a licensed version.
    01-18-2012 11:02 AM in reply to: amahjoub
    Download full version, but not plain autocad, it will work the same , draw with it and send it out.
    (or you can send them .dxf instead of .dwg)
    *Expert Elite*
    JGerth
    01-18-2012 03:42 PM in reply to: amahjoub
    Once a file has been edited in a student version, it will always have the student stamp, and willinfect any drwing it's used in with that stamp.  The reason for that is to prevent exactly what you are tying to do.
    You could try a 30 day trial version, probably on a fresh PC and redraw everything.  Or, install Draftsight for free, and use that legally.
    *Expert Elite*
    01-18-2012 04:30 PM in reply to: amahjoub
    Patchy's DXF suggestion violates your end user agreemenr, so you know. AFAIK.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    Patchy
    01-18-2012 04:56 PM in reply to: mathewk
    Product Support
    LanceEdwards13
    01-19-2012 09:26 AM in reply to: amahjoub
    This is correct. Once a file has been marked as a student version it will never be able to be used in a commercial version without that watermark showing. There is no way to remove this on your end...legally.
    Lance Edwards
    Product Support Technical Specialist
    Product Support
    Autodesk, Inc.
    New Member
    amahjoub
    01-25-2012 04:18 AM in reply to: amahjoub
    Thank you for the replies. I will just redo the drawing on their laptop :smileysad:
