• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Only Sketchbook ribbon is showing in AutoCAD !!
    151 Views, 1 Replies
    06-27-2012 12:43 PM
    Hi All,
    I just upgraded to AutoCAD 2012 the Ultimate Suite. After downloading all the softwares in the suite, when I open AutoCAD MEP or AutoCAD Architecture it only shows the Sketchbook ribbon.
    I attached a picture to show what I mean, the picture is for AutoCAD Architecture but I also get the same with AutoCAD MEP.
    Thanks in advance for your help.
    Please use plain text.
    Re: Only Sketchbook ribbon is showing in AutoCAD !!
    07-03-2012 04:59 AM in reply to: SummerMankarios
    I don't know Architecture or MEP (as here is not the forum for that :smileywink: ), but I would first try to reset the profile. For AutoCAD (plain AutoCAD) it was introduced with version 2012 that you have the option for resetting the AutoCAD profile by starting the reset from the Windows-Start-menu ==> section Autodesk and then your AutoCAD-vertical .... look if you find a similiar reset-option within your Windows-menu for Arch or MEP.
    Good luck, - alfred -
    BTW: the forum for Arch could be found >>>here<<< and for MEP >>>there<<<
    Alfred NESWADBA
