• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Online tab problem
    69 Views, 1 Replies
    08-03-2012 02:38 AM
    Hello everyone,
    I have a problem with autocad WS on Autocad 2012, I've used a workstation of a collegue of mine, and I access to some personal drawings thru the "online" tab, unfortunately, when I press the "online drawings" and a popup windows appear to ask my Autocad WS data, I forgot to uncheck the "Remember my data" and now every time I click on "online drawings" it connect to my Autocad WS account.
    Is it possible to remove my data from Autocad ? I tried to click on Logout on Autocad WS but it doesn't work.
    Please help me, I have several personal drawings on it and I don't won't that my colleagues open or modify them
    Thanks for helping
    Please use plain text.
    New Member
    Re: Online tab problem
    08-03-2012 07:52 AM in reply to: TheAztek
    After a search on the "Documents & settings" folder I found the solution by myself :manlol:
    If someone suffer my same problem, just point your resource manager to:
    C:\Documents and Settings\_name_\Local Settings\Application Data\Autodesk\AutoCAD 2012\R18.2\_language_\AutoCADWS\0.1 and rename the files token.xml to token.old or other dummy extension.
    It works ! :smileyvery-happy:
