AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Object snap bug?
- Highlight
- Email to a Friend
Re: Object snap bug?
- Highlight
- Email to a Friend
>> When she uses the object snap, or same other commands (for example match properties),
>> the cross in the drawing window disappears and become the regular windows pointer.
First: object-snaps are no command, they can't be used like starting a command.
And a general statement: if you see the Windows-cursor (arrow by default) the AutoCAD-Window does not have the focus. So what happens if you click into the graphic-area of AutoCAD then?
Can you upload a screenshot showing us your commandline (so we see what command is started and what option is selected + the cursor visible as Windows-arrow?
What you can try is to look for servicepacks and to play with the hardware-acceleration (command _3DCONFIG ==> manual tune ==> and invert the current state for activated/not activated). If that helps then let us know what graphic-card you have and what driver you are using.
Good luck - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
alfred.neswadba wrote:Hi,
And a general statement: if you see the Windows-cursor (arrow by default) the AutoCAD-Window does not have the focus. So what happens if you click into the graphic-area of AutoCAD then? Ok, it's not a command, lets say a use a commans, for example dimension or polyline, and then use the object snap function. But I suppose you understood what I meant the first time =)
As I wrote in the first message AutoCAD window is active and the active drawing IS active. When I click in to the active window with the windows cursor is works just as the autoCAD-cursor would've been active.
Can you upload a screenshot showing us your commandline (so we see what command is started and what option is selected + the cursor visible as Windows-arrow? I'm sorry, I can't at the moment since it isn't my computer the problem is occuring on. I thought this was pretty clear from the first post. She uses and "snapable" command, for example line/polyline/dimension, then any object snap, for example "nearest", and only the the standard windows cursor gets active even thought AutoCAD, and the current drawi
What you can try is to look for servicepacks and to play with the hardware-acceleration (command _3DCONFIG ==> manual tune ==> and invert the current state for activated/not activated). If that helps then let us know what graphic-card you have and what driver you are using. Since our whole office are using the same hardware it shouldn't be a graphic-card problem, I'll check out the driver though and apdate AutoCAD to latest service-pack.
- Highlight
- Email to a Friend
I can't be certain but it sounds like another window is "popping" up off screen which is a big thing in 2012. To find the missing window, hold the ALT button down and hit the spacebar. Strike the M button and use your arrow keys to start moving the window around. Once it starts moving you can move it with your mouse. This must be done directly after initiating the command that would pull up the new window.
- Highlight
- Email to a Friend
maybe the color of "2D or 3D Auto Snap marker" the same color as your background.
- Highlight
- Email to a Friend
Even if that were true, that would not cause the "regular windows pointer" to appear.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Highlight
- Email to a Friend
rasmusre wrote: Ok, it's not a command, lets say a use a commans, for example dimension or polyline, and then use the object snap function. But I suppose you understood what I meant the first time =)
So let's say you want to draw a line from the ENDpoint of another line.
You start the LINE command, then what?
Are you typing in END, or using Shift+right click to access the context menu, or something else?
IOW - how are you initiating the object snap?
R.K. McSwain
- Highlight
- Email to a Friend
Maybe you should try to run a repair on the AutoCAD installation.
- Highlight
- Email to a Friend
Is this problem specific to a drawing?
