AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Not just another Arial Narrow truetype too bold issue...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone
Some of you may have encountered the old chestnut that is arial narrow and other truetype fonts displaying too bold, and the usual problem of them having z values, fixed by flattening the text.
I have this problem but there is a twist to the story - all my text has been well and truly flattened. When I print from model space, it looks fine, from paper space through the viewport = too fat. This is where it gets really strange. When I change space on text (which had a z value of 0 in model space) to paper space, it suddenly has a z value of 1058.322. If I then set the z value to 0, it looks fine. Following this, if I then change space back into model space, the z value leaps from 0 to 569.161 (half of 1058.322, as the scale of viewport is 1:500(m), or 2:1) and is too fat again, and stays fat when I reset to 0. I have checked the center z value of the viewport and it is 0, and the ucs in paper space is world.
I am a little bamboozled - Any suggestions?
cheers
Re: Not just another Arial Narrow truetype too bold issue...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
Did you get any resolution to this? I'm having the exact same problem which I can't find an answer for anywhere on the internet. I too stumbled on changing the space of the text and how AutoCAD then gives it a z value.
Does anyone have a solution?
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
SET ucs world and plan world then wblock the data to a new file and see if this fixes the issue.
don't ask why, just do it.....
might work might not
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your viewport uses a different UCS other than WCS?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks guys, although I've just managed to solve it. In my case the 'target z value' was non-zero. Corrected by entering 3dorbit in the viewport and changing the z target value in the properties box to 0. While doing a wblock of the drawing often works, it's always good to know what actually causes the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Success!
Top stuff mrdrafty, that was driving me insane!
Thanks everyone
