• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor ipi
    Valued Contributor
    Re: No Snap when No Command Active??
    05-14-2011 06:50 AM in reply to: jerry.ford
    Boo!  I, too, do not like not being able to cruise around my drawing and insopect the element of the drawing using my snap setting.  please log my vote to add an option to run snap in either mode.
    David Hassan
    IP Illustration
    www.ipillustration.com
    Please use plain text.
    Member
    sbanister
    05-16-2011 03:38 AM in reply to: JEeten
    I agree completely that the 'old' snap behaviour must be available. I used the snap to check the alignment of objects within my drawings, it was very useful to check the 'Y' coordinate for many objects/items.
    This spoils an otherwise quite good product. Autodesk, please sort it
    Simon
    England
    Active Contributor
    elprim
    05-17-2011 02:50 AM in reply to: JEeten
    Have someone idea what to do, when by active command isn't activated snap.
    As a acade user, I tray to use Multiple wire bus - Another bus, and by this command
    snap isn't activated and isn't possible to start from right position
    Regards, Vito
    PS I use acad for other work too, and I'm not happy that there is no way to get old SNAP
    Kind regards, Vito
    New Member
    Armaline1
    05-23-2011 05:07 PM in reply to: sbanister
    I also agree that this is a very important feature that a lot of us use and it seems Autodesk in their own wisdom have removed it.
    I require the crosshairs to snap or bounce when the snap is active.
    This could be added as an extra setting to snapmode or similar.
    Hope this is resolved in SP1 as I am reverting to 2011 to it is fixed.
    Seems a waste of a subscription to me!!
    06-08-2011 12:29 PM in reply to: JEeten
    I have also used snap in this fashion for quite a long time since release 10 way back when in college days, this needs to
    be corrected if possible as a hotfix.  It is extremely irritating to have to enter a command first to simply check a line-up,
    I have to stream line and keep things simple guys as I'm on a tight schedule (as I'm sure many others are)
    We need to be able to goto straight from A to B .  Not goto A then have to goto C D E F before I get to goto B.
    Just my 2 cents.  Thanks for listening to us.
    06-13-2011 09:53 AM in reply to: JEeten
    I thought this was a bug. Guess its a new feature.
    Our office is also unhappy about this.  If there is somewhere else to complain about this and get this fixed a link to such a place would be great, and perhaps we can all get this changed. Guess its time to become an AUGI member.
    Distinguished Contributor
    06-21-2011 06:14 PM in reply to: JEeten
    I'll add my vote to BRING IT BACK!!
    I thought at first some setting changed.  Now I see it's Autodesk that made the change without a way to maintain the snap as it was!
    It seems subscription is becoming a waste of money as most of the "improvements" go to other platforms or, like this, mess up basic Autocad.
    Bring it BACK!
    R
    Active Member
    rhomeier
    07-26-2011 08:45 AM in reply to: RFUSE
    I agree everyone else, bring back the ability to toggle SNAP Mode On and Off. I don't mind having it turn off automatically when exiting a command, but I would like the option to toggle it back on when I'm checking to see if things are lined up or evenly spaced.
    Autodesk needs to understand that most electrical folks are a bit meticulous, if not a tad OCD, but it's what makes us good at our jobs. Everything has to be straight, neat and even!
    Member
    08-09-2011 08:34 AM in reply to: rhomeier
    I vote to BRING IT BACK!!!!
    New Member
    ScottSmith3420
    08-23-2011 06:59 AM in reply to: JEeten
    There definitely should be an override, especially in AutoCAD Electrical. A lot of commands are derived from right-clicking on an object or wire. If I right-click on a wire to move a wire number I want it to snap to a grid point so I can align multiple wire numbers at that same snap grid. The first wire number move does appear to to land on a snap point, but because the wire number move command remains active, any subsequent moves are just random points  Yes, I know about the align command, but that means having to quit the current move command and then start the align command. This is NOT being productive. And, this demonstrates that snap does not always turn on when a command is active. Hitting F9 while in the wire number move command does not turn snap on and off.
