• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    New block editor is not working for my need; can any one help?
    238 Views, 2 Replies
    04-23-2012 11:03 PM
    Is any one out there can help me in  the following problem,
    The new block editor is not working for me;
    In the old cad we had the block editor where you can add and remove entities from the block; how will I do that now?
    Please use plain text.
    pendean
    Re: New block editor is not working for my need; can any one help?
    04-24-2012 05:21 AM in reply to: Davidsajuphilip
    BLOCK command is the old classic and is still around.
    BEDIT command pretty much does the same thing, and so much more too.
    REFEDIT let you edit a block in place.
    BATTMAN edits attributes without opening the block, and ATTSYNC command syncronized it all afterwards.
    So... which new editor do you speak of that's not working for you? All the above have been around for a very long time (and most likely in your "old" cad) and nothing new has been offered yet. Elaborate, or better yet, offer a DWG example for others to try and edit your block.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    pendean
    04-24-2012 05:22 AM in reply to: pendean
    I see from another post, you simply got stuck in REFEDIT and it appears you solved the issue.
