• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    New Semi-Ortho
    581 Views, 6 Replies
    01-20-2013 09:04 PM
    The F8 key has been used for years to turn ORTHO on or off. The option to pick ORTHO on the status line below the drawing area has always been available as, since AutoCAD 2006, holding down on the SHIFT key will give you instance ORTHO.
    However on my laptop I have AutoCAD 2010,  and this feature does not work. On the other PC AutoCAD 2009 installed, and works fine. Is there a setting to be ajusted or something else that I havo no idea.  Anybody have an anwser or a clarification...
    Thank You Alex B.
    Please use plain text.
    Re: New Semi-Ortho
    01-20-2013 11:41 PM in reply to: bluebull
    for me it works with 2010 too. And I would not know a sysvar that does influence it working or not.
    Have you installed the latest servicepack for AutoCAD?
    Does that happen only in one drawing or also in new ones?
    What happens if you login to your workstation with anohter user-account and try it again (so the AutoCAD profile is as clean as possible).
    - alfred -
    Alfred NESWADBA
    Re: New Semi-Ortho
    01-21-2013 01:27 AM in reply to: bluebull
    bluebull,
    see the System Variable
    TEMPOVERRIDES, should be 1
    Hope that helps
    Henrique
    Re: New Semi-Ortho
    01-21-2013 01:46 AM in reply to: hmsilva
    @hmsilva:
    - alfred -
    Alfred NESWADBA
    Re: New Semi-Ortho
    01-21-2013 01:52 AM in reply to: alfred.neswadba
    Thank you, Alfred
    Cheers
    Henrique
    Active Contributor
    Re: New Semi-Roth
    01-21-2013 08:23 PM in reply to: hmsilva
    TEMPOVERRIDES,  should be 1......this is exactly what makes sense to resolve my small deception with Semi- Ortho,
    I  appreciate your prompt relay on the matter.
    Thank you, AB
    Re: New Semi-Roth
    01-22-2013 01:02 AM in reply to: bluebull
    Glad I could help
    Henrique
