• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Need help removing a MAP feature in ACAD dwg
    69 Views, 2 Replies
    12-12-2012 06:49 AM
    Greetings.  I work with a colleague who is running AutoCAD MAP.  When he makes a block or saves a drawing, at the origin is a 3D, downward pointing arrow which in 2D plan view obscures anything around the origin.  I open his blocks or drawings in ACAD2012 or 2013 with the same issue.  In plan view, the 3d arrow appears as a circle with radial lines running out from the center.  If I save the drawing in my ACAD that feature is still there.
    I've attached a png screenshot of what I'm talking about.
    Is there any way to get rid of that feature, which is apparently coming from his MAP version of ACAD?  I've looked for settings on his machine and on mine.  I have played with the Workspace setting.  I've looked in Options for anything.  Maybe there is a system variable.  Does anyone know how to control the visibility of this 3D arrow in ACAD?
    Thanks for any help.
    Erik
    Please use plain text.
    Valued Contributor
    Re: Need help removing a MAP feature in ACAD dwg
    12-12-2012 06:57 AM in reply to: edweberg
    GEOMARKERVISIBILITY command
    Valued Contributor
    12-12-2012 07:01 AM in reply to: Patchy
    Awsome.  Thank you!
    E
