• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Navigation Cube isn't visible on screen
    305 Views, 2 Replies
    08-31-2011 07:16 AM
    Need a little help here. On one of our computers, the navigation cube isn't visible. We've tried;
    CUBE = ON
    NAVVCUBE = ON
    NAVVCUBEDISPLAY = 1
    CUBE - settings - all different positions to display on screen
    What other options/switches should we try?
    Please use plain text.
    Re: Navigation Cube isn't visible on screen
    08-31-2011 10:34 AM in reply to: tstorzuk
    Use the sysvdlg command at the command prompt and scroll down and find the variables that control the cube settings and adjust accordingly.  When you pick a variable there it gives the options to decide what to set it to.
    *Pro
    nestly
    08-31-2011 01:52 PM in reply to: tstorzuk
    NAVVCUBEDISPLAY = 1 only displays the Viewcube when you're in a 3D Visual style  (ie not 2D wireframe)
    Try NAVVCUBEDISPLAY = 3 to always have the Navvcube displayed.
    Also remember that each viewport has it's own viewcube display setings, so if NAVVCUBEDISPLAY was 1 when you created the viewport(s), you'll have to change it for each viewport.
