• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    My Autocad open like few diferent apps but than there is only one process...
    102 Views, 1 Replies
    12-11-2012 07:03 PM
    My Autocad opens like few apps (see attachment) and than there is only one process. Nevertheless the process ocupy much space: The sample is for 2d 13.878 KB file. My cad goes really slow and my laptop has 4GB RAM and the system is 64bits Windows 7...
    If somebody has a clue what happens thanks a lot for help!
    Please use plain text.
    *Expert Elite*
    Re: My Autocad open like few diferent apps but than there is only one process...
    12-11-2012 10:08 PM in reply to: BasiekF
    To show how much memory is used by this task you should have shown us the "process"-side from the taskmanager :smileywink:
    Well, it could be there are references used like images or xrefs, or you have a quite good structure used with blocks, so the drawing-filesize is small, but it shows a lot of geometry. E.g. I did a sample drawing having less than 100k, but you can't open it on a 4GB/32bit workstation because of it's memory usage.
    The most important question now is what exactly do you mean by "cad goes really slow"? What is slow? Cursor hangs, object-selection, object-snaps, loading the drawing, saving the drawing, ...
    The other question is: what os do you have and what hardware (processor, memory, graphic card, ..)
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
