• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    raul
    Accepted Solution
    Multileader match orientation to layout?
    1540 Views, 3 Replies
    11-19-2010 07:48 AM
    Is it really so that multileaders cannot be aligned to layout like annotative Mtext? When my technician told me "it's not working", I started to look at it. Spending half a day reading help and googling around I feel like dropped from the moon.
    How can I force my leaders to match layout orientation? Using AutoCAD 2011
    Attached dwg example of the problem.
    Thanks in advance,
    Raul
    Please use plain text.
    Valued Contributor
    Re: Multileader match orientation to layout?
    11-19-2010 12:38 PM in reply to: raul
    create a new user coordinate system in the viewport. click inside the viewport to get into modelspace, type ucs, n (for new), v (for view) and enter. If you so desire, you can type ucs again and the s (for save) and give the new ucs a unique name.
    11-20-2010 04:08 PM in reply to: raul
    Since I usually have only one layout per drawing I use UCS View option. It is easy to change back to UCS World when I am done with text, dims, and mleaders if necessary. I find it saves the step of creating and using a named UCS. If I had multiple layouts in a drawing all using the same alignment then I would use a named UCS.
    Nancy
    Active Member
    raul
    11-21-2010 05:01 AM in reply to: gwhite
    Thanks for the workaround. This helps to align leaders to layout, but not update them when viewport is rotated.
    So the answer to my first question is Yes, unfortunately. I think annotative leaders in Autocad need further development..
     Raul
