AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Multileade r match orientatio n to layout?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it really so that multileaders cannot be aligned to layout like annotative Mtext? When my technician told me "it's not working", I started to look at it. Spending half a day reading help and googling around I feel like dropped from the moon.
How can I force my leaders to match layout orientation? Using AutoCAD 2011
Attached dwg example of the problem.
Thanks in advance,
Raul
Re: Multileade r match orientatio n to layout?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
create a new user coordinate system in the viewport. click inside the viewport to get into modelspace, type ucs, n (for new), v (for view) and enter. If you so desire, you can type ucs again and the s (for save) and give the new ucs a unique name.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Since I usually have only one layout per drawing I use UCS View option. It is easy to change back to UCS World when I am done with text, dims, and mleaders if necessary. I find it saves the step of creating and using a named UCS. If I had multiple layouts in a drawing all using the same alignment then I would use a named UCS.
Nancy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the workaround. This helps to align leaders to layout, but not update them when viewport is rotated.
So the answer to my first question is Yes, unfortunately. I think annotative leaders in Autocad need further development..
Raul
