• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Product Support
    Re: Multileader Align Problem
    03-07-2012 08:17 PM in reply to: joel
    Great job Joel.  Thank you for this  routine within the community to share.
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Active Contributor
    itbemedg
    03-08-2012 08:30 AM in reply to: joel
    A HUGE thanks to both of you!!
    New Member
    02-04-2013 10:22 AM in reply to: MichaelBussiere2
    I have loaded the MLLA.lsp file but can't seem to get it to work. I'm in AutoCAD 2010, they haven't fixed this by now?
    Valued Contributor
    02-05-2013 07:25 AM in reply to: amandaachelpohl
    I was able to get the MultiLeader to work by editing the settings in the dialog boxes.
    Under Format, Multileader Style.
    See the attached screen shots with my settings.
    I have a left justified & right justified style depending weather you are pointing right or left.
    Let me know if it works for you.
    Everything in existence was first an Idea
    Autodesk Plant 3D Premium 2012
    Autodesk MEP 2012
    HP 3.2 Mhz CPU 16 ram
    1TB 7200 rpm SATA 3Gb/s hard drive
    2GB DDR3 NVIDIA GeForce GT 530
    HP 2311x 23" LED Monitor
    Valued Mentor
    02-05-2013 07:45 AM in reply to: MichaelBussiere2
    Huh, I didn't think anyone used MLEADER when QLEADER is available.  MLEADER seems so cumbersome compared to QLEADER, once I tried it to see what the issue was all about with the justifications.  QLEADER has the same settings dialog BTW.  I just wonder what settings the others had where they were having a justification problem and had to use a LISP to accomplish a core command?
    Valued Contributor
    02-05-2013 08:32 AM in reply to: steve216586
    My bad! This was Qleader.
    Sorry folks.
    But I do believe they are similar.
    Autodesk MEP 2012
