• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Mouse is "jumpy" or setting mouse resolution
    407 Views, 9 Replies
    12-17-2012 08:38 AM
    When I open a large facility building drawing my mouse is "jumping" on the screen.
    The resolution of the mouse does not allow me to select obejects on the screen because the mouse jumps in large increments.
    I do not have this problem on smaller drawing, such as electrical schematics.
    Is there a setting to increase the resolution of the mouse movemrnt id AutoCAD?
    Please use plain text.
    Re: Mouse is "jumpy" or setting mouse resolution
    12-17-2012 08:44 AM in reply to: fxcastil
    ROLLOVERTIPS ==> set it to 0
    SELECTIONPREVIEW ==> set it to 0
    HTH, - alfred -
    Alfred NESWADBA
    12-17-2012 09:25 AM in reply to: fxcastil
    Is SNAP on (F9) ?
    (I don't mean OSNAP)
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Pro
    12-17-2012 09:39 AM in reply to: troma
    The biggest culprit I've come across is using the Layer Palette instead of the "old fashioned" dialog box.
    You can either use the command CLASSICLAYER, or set the sysvar LAYERDLGMODE to a value of 0
    12-17-2012 11:39 AM in reply to: fxcastil
    The "snap" is not on.
    Thanks for all the suggestions, I tried all the above suggestion (variable setting) but I still have the same problem.
    If I zoom out on the drawing I do notice the "jumpy" mouse problem.
    But if I zoom in on this large facility drawing I have the "jumpy" mouse problem.
    I sometimes see a blue faded box close to the mouse pointer.
    More suggestions would be most appreciated.
    *Pro
    12-17-2012 11:42 AM in reply to: fxcastil
    The blue box sounds like the Selection Cycling is turned on.  Enter the sysvar SELECTIONCYCLING  and set it to 0
    12-18-2012 07:21 PM in reply to: fxcastil
    Thanks Murray, the "SELECTIONCYCLING" Variable fixed my jumpy mouse, you have earned your Distinguished Mentor Status.
    With so variables to set, I now need  to find a complete variable list for 2011 AutoCAD.
    12-18-2012 11:33 PM in reply to: fxcastil
    You can find it >>>here<<< or, if you have installed ExpressTools then start command SYSVDLG.
    - alfred -
    Alfred NESWADBA
    *Pro
    12-19-2012 07:04 AM in reply to: fxcastil
    Cool!  Glad I could help
    SugarCAD
    12-27-2012 12:29 PM in reply to: fxcastil
    You should setup your acaddoc.lsp to set your System Variables as you like them on startup.
