• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Modify annotative blocks in XREF
    152 Views, 1 Replies
    08-30-2012 10:12 AM
    I have inserted an XREF with annotative blocks.  The blocks in the original drawing are 1:1.  In the new drawing I want to plot the XREF at 1:250.  How do I set the annotative scale to the blocks with out adding scales to the original drawing?
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: Modify annotative blocks in XREF
    09-01-2012 02:05 PM in reply to: malcolj
    Check the blocks in your xref if they are set with 1:250 annotation scale?
    if they are? then all is to be done is to set the annotation scale 1:250 to host drawing.
    if it doesn't work? close autocad and try again.
    Cheers
    Moshe
