• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Pro
    Modify Sheet Set Custom Property Definitions
    140 Views, 1 Replies
    05-03-2012 08:59 AM
    After all these years, I FINALLY decided to get my head around the Sheet Set Manager (kudos to Kate Morrical's video series).
    I understand the need to create custom properties, and I can see that you can either "add" or "delete" custom properties, but is there any way to CHANGE the property after it's been defined?
    For example, if I create a custom property complete with a default value, but discover later that I made a spelling mistake (eg. "Darwn By" instead of "Drawn By"), is there any way to MODIFY it?
    Please use plain text.
    *Expert Elite*
    JGerth
    Re: Modify Sheet Set Custom Property Definitions
    05-03-2012 01:38 PM in reply to: murray-clack
    you can change the value, but not the label. I would guess that the thinking is that the custom property _may_ already be referenced by a field in a drawing, and changing the label would break the linkage.
    I don't know if that's an accurate guess on my part or not: .dst files are not readable as text or xml.  Check with the SSM Editor on jtbworld.com - if anyone can do it, Jimmy Bergmark can..
