• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    roadwayws
    Model Space and Title Blocks
    294 Views, 5 Replies
    01-04-2012 03:06 AM
    Hello it has been quite some time that I have done this. I received a file that the client has that is set up into Model Space and 2 tabs for title Blocks they already have.
    After doing the dwg in Model Space how do I get it into the title block Pages.
    And as Far as changing the title block I thought there was a file that brought up anything that needed to be changed.
    :smileyembarrassed:
    Please use plain text.
    Re: Model Space and Title Blocks
    01-04-2012 05:04 AM in reply to: roadwayws
    These "tabs" are called "Layout" in AutoCAD, and to get the model-geometry visible on the layouts you have to place at least one viewport plus zoom/pan within the viewport to see the geometry you like to see in the scale you want.
    For more info look >>>here<<<.
    That's more difficult to answer as we don't see what you have. If it's a block, a XRef, single geometry containing lines and text ... it's differently to handle depending on the geom-type.
    The most usual (structured) case is you have an AutoCAD-Block holding attributes, to modify the text-type data you just have to double-click the block.
    - alfred -
    Alfred NESWADBA
    roadwayws
    01-04-2012 05:30 AM in reply to: roadwayws
    Thanks I will give it a try later today
    roadwayws
    01-04-2012 05:46 AM in reply to: roadwayws
    It turns out that the "Model Space has a "Title Block" in it also.
    So when I go to move it into the title block Page They over lap and dont line up.
    I have to delete one or figure out something because it comes in as a complete
    block with the outline of the Model space page.
    :smileyembarrassed:
    01-04-2012 05:51 AM in reply to: roadwayws
    In well structured drawings the title block has to be placed on the paperspace of the layout, I would delete it from modelspace and _INSERT it in each layout.
    - alfred -
    Alfred NESWADBA
    roadwayws
    01-04-2012 06:17 AM in reply to: roadwayws
    Thanks, Its a problem getting DWGs sources from other places.
