• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    jshaw05
    Accepted Solution
    Missing LInes When I Try to Print to .pdf
    1976 Views, 9 Replies
    02-22-2011 01:46 PM
    Hi!
    I'm trying to print to .pdf using AutoCAD 2011 using a print driver called CutiePDF.  However, when I go to print, the lines that I can see in my AutoCAD file don't show up in the print preview.  Any ideas?
    Please use plain text.
    Distinguished Mentor
    jaich
    Re: Missing LInes When I Try to Print to .pdf
    02-22-2011 05:00 PM in reply to: jshaw05
    What happens when you use the native PDF creator?  Does this happen with just one file, or all of them?  Have you audited/recovered this file?
    Member
    02-22-2011 05:27 PM in reply to: jshaw05
    You might have to audit & recover the drawing and purge it as the drawing may have some unused data which might be creating a problem in creating the PDF. Also check if you got any wipeouts in your drawing as a 3D object it create problem in printing.
    Active Member
    jshaw05
    02-23-2011 09:33 AM in reply to: jshaw05
    Hi All,
    When I try to plot with the default .pdf printer, the same issue happens.
    I also tried auditing and recovering and purging the file, and the lines are still not showing up.
    jaich
    02-23-2011 11:46 AM in reply to: jshaw05
    Are the lines that aren't showing up on a no plot layer?
    Active Member
    jshaw05
    02-23-2011 11:57 AM in reply to: jaich
    Hi!
    Yes, that fixed it!  Thanks!
    New Member
    Shoyur
    03-28-2011 06:56 AM in reply to: jshaw05
    hmm, i have made a CD with all pdf of all drawings for a customer, he sent me an email this morning saying many drawings have hidden lines.
    I test it many times here and realize sometimes whe i print in pdf, lines dont show up, only some of them, its random...
    i have this version :
    it is the original autocad pdf driver i think..
    lines are not on a special layer.. they print well (sometimes) and of coruse print well in paper..
    is there a patch for this, or a well working other driver.
    we paid much for this..
    thank you
    New Member
    Shoyur
    03-29-2011 07:10 AM in reply to: jshaw05
    hmmm.. i tried this on a another computer (our 2nd license) and it does the same thing, its still windows xp on it, but a totally different hardwares/softwares setup..
    we have lost at least 500$ of time trying to find the problem and repairing the errors it made..
    05-04-2011 10:19 AM in reply to: Shoyur
    Are the lines missing in the print preview? If they are missing when you open up the new PDF it may be that the PDF program is outdated. I use AutoCAD 2011 and when I open a PDF in Acrobat 6.0 alot of the lines aren't there, but if I open it with Reader 10 it's OK.
    03-29-2012 12:09 PM in reply to: jshaw05
    We have been experiencing a similar problem. We are using AutoCAD 2012 and Adobe Acrobat 8 Pro and on some prints (PDFs) there are missing lines. We have tried all the normal stuff (ie purge, audit, recover, line type, etc.) and none of this seems to have worked. The missing lines seem to be random. Is it possible that this is just a compatibility issue with AutoCAD and Adobe and if so does anyone know a combo that would work?
