AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Mirrored dimensions and text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Using the same template Text and Dimension style all of the sudden the text is vertical and mirrored and the dimension text is mirrored under the dim line ( above the dim line in normal conditions)
What could be the problem? I did not change anything in the settings, voluntarily, I use this template for years and never had a problem with it till now.
Can anybody help me out? I have spend a few hours searching for a fix. see the bubbled text in the attached PDF.
Thanks in advance.
Re: Mirrored dimensions and text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
have you verified that the UCS is set to the same direction that the other drawing parts are? It looks like you have set the UCS to look from "behind" to the geometry, so new dimensions seems to be mirrored.
BTW: uploading a drawing creates better answers, seeing the PDF makes it visible, but what happend to your drawing exactly can't be said. So all above is just guessing. ![]()
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
oh my God, the minute you mentioned UCS it only took me a second to revert back to WORLD. I never checked that because I never changed the coordinates or view. I always work in 2D and use the same axes and directions.
Regardless of the cause it is all good now and i thank you for that,
have a good weekend,
Felix
PS
Point taken. Next time I will attached the whole dwg. Thanks again
