• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Microstation to AutoCAD
    390 Views, 4 Replies
    02-09-2012 09:13 AM
    Is it better to convert a Microstation Design to AutoCAD or is it better to insert Microstation Design into an AutoCAD Design?
    Thanks for any comments.
    Please use plain text.
    Patchy
    Re: Microstation to AutoCAD
    02-09-2012 09:36 AM in reply to: corneliuswright7842
    Microstation opens .dwg looking better.
    Autocad opens .dgn has problems with linetype, fonts.
    02-09-2012 09:49 AM in reply to: Patchy
    But the End User is using AutoCAD.
    Patchy
    02-09-2012 09:57 AM in reply to: corneliuswright7842
    Convert to .dwg with MS will give you the same result as if you importdgn with Autocad.
    02-13-2012 07:14 AM in reply to: Patchy
    Thanks for your Help.
