• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    BillMazza
    Metric Conversion
    181 Views, 17 Replies
    05-03-2012 09:15 AM
    I created a drawing in Metric, from an Architect's print.
    I finally received their drawing in a workable format, that I inserted the building I drew, into their drawing, both are in Metric.
    For some reason, my drawing comes out HUGE in their drawing file. When I scaled it down, the building just didn't match up at all, even though all the dimensions were the same.
    I really need help with this one quickly, if I could trouble someone to take a look at the drawing.
    Please use plain text.
    Patchy
    Re: Metric Conversion
    05-03-2012 09:20 AM in reply to: BillMazza
    Don't be shy, upload :smileyvery-happy:
    BillMazza
    05-03-2012 09:20 AM in reply to: Patchy
    No I cannot do that. Not with this.
    Patchy
    05-03-2012 09:45 AM in reply to: BillMazza
    send it to me
    BillMazza
    05-03-2012 09:46 AM in reply to: Patchy
    I just did, thank you Patchy
    Patchy
    05-03-2012 10:05 AM in reply to: BillMazza
    When an Architect uses Autodesk Architecture and you're using plain Autocad you shouls check this "AECDWGSETUP" as you can see in the two photos attached. Both should be the same.
    BillMazza
    05-03-2012 10:11 AM in reply to: BillMazza
    I don't have that command in basic AutoCAD 2012.
    I just have AEC Version
    Patchy
    05-03-2012 10:15 AM in reply to: BillMazza
    It was a real problem with Civil and Architecture too, one use decimal of a foot and one use feet and inches.
    Only fix is to scale one the drawing (the one that don't use AEC)
    BillMazza
    05-03-2012 10:20 AM in reply to: Patchy
    That's the problem I'm having, I don't know what to scale too. I have two drawings, drawn in metric, to the exact same dimensions, and when I try to combine the two drawings, they don't match up at all.
    I swear if this is an Autodesk issue I am going to be extremely upset. Do you realize how embarrassing it will be to go into my boss and just shrug my shoulders and say I don't know what the deal is?
    I mean which drawing is correct?
    Patchy
    05-03-2012 10:24 AM in reply to: BillMazza
    Your archi uses meter, you're using mm
    scale your drawing down 1/1000 ;  it will mess up dimensions, if you can copy the dimension style from your archi and use it, it will be the same.
