• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Hans
    Measure/divide & Block orientation
    732 Views, 6 Replies
    06-01-2010 07:11 PM
    For once I have to place many asymetric objects uniformly with Alignment
    along a convex circular arc (2D). So I try Measure or Divide using my
    Block but it flips my Block so it is aligned with the inside of the
    curve (closest to the curve centre) not the outside and the blocks are
    turned upside down. If I draw an arc concave up it plots OK. If I draw
    a Spline (single curve or reverse curve (S curve) in my desired
    orientation, it also plots OK.
    I have tried all combinations of UCS but to no avail. The block is not
    dynamic so there has not been any Alignment set.
    Any clues??
    Hans
    Please use plain text.
    Active Contributor
    Re: Measure/divide & Block orientation
    06-01-2010 11:24 PM in reply to: *Hans
    For Align block with object? [Yes/No] :
    Say NO
    Ram.D Edited by: ram.d on Jun 2, 2010 11:55 AM
    Ram.D
    *Hans
    06-02-2010 01:02 AM in reply to: *Hans
    I don't know what that means.
    I want the Block to align tangentially and that is what it does but it
    inverts it (wrong side of the curved path).
    Drawing Attached Hans
    On 2/06/2010 4:26 PM, ram.d wrote:
    > For Align block with object? [Yes/No]:
    > Say NO
    > Ram.D
    Active Contributor
    06-03-2010 04:57 AM in reply to: *Hans
    Sorry I could not open the attached file as I am using AutoCAD 2009.
    But when I try using block, it works as I said NO to Align block with object.
    Possible, save the file in lower version and send it to me.
    Ram.D
    Valued Contributor
    bjornhgr
    06-18-2012 03:38 AM in reply to: ram.d
    To follow up on this: I have the same prolem, and if your block has a certain direction, it doesen't necessarily help to chose no for alignment. I need my blocks aligned with the line AND pointing in the right direction on the right side of the line, like in the first figure, not the next two.
    Anyone got a tip?
    06-21-2012 02:18 AM in reply to: bjornhgr
    create a new block where the contens within the blockdefinition are rotated by 180° (or mirrored, whatever you like).
    - alfred -
    Alfred NESWADBA
    heinsite
    07-01-2012 05:17 AM in reply to: alfred.neswadba
    Or, since dynamic block parameters are available in 2010, add an alignment parameter.  They can be a little tricky to get used to, but are quite handy.  You could specify them as either tangential or perpendicular... which ever works best.
    Dave.
    Dave Hein, P.E.
