• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    EduardoBoarati
    MTEXT With Problems
    894 Views, 5 Replies
    04-04-2011 06:17 AM
    Hi everyone
    I have an issue with the MTEXT. When I try to edit what is written inside the windows of the MTEXT, the text rotates and goes to the vertical position. Even If i change the Rotation angle to 0 on properties, when i finish editing the text it rotates again to the vertical position.
    The issue is on the video.
    Please use plain text.
    Distinguished Contributor
    Re: MTEXT With Problems
    04-04-2011 07:24 AM in reply to: EduardoBoarati
    There is something wrong with the style used. I was able to copy/paste into a new mtext box without formatting.. i used the "Standard" style, and i was able to edit it. This is a very strange bug.
    04-04-2011 07:39 AM in reply to: EduardoBoarati
    For some reason the font "arial unicode ms" is buggy with ACAD...in your dwg, whenever I changed the font in the same style, everything came out fine.
    EduardoBoarati
    04-04-2011 11:02 AM in reply to: JACERAC
    thanks guys for your help,
    If i discover that its really a bug with the arial unicode ms i'll post it here later.
    Thanks again.
    EduardoBoarati
    04-08-2011 10:26 AM in reply to: EduardoBoarati
    Hi !!
    I found out what was happening.
    every font with the @ at the begining like "@arial black"  is made to right in the vertical position.
    to solve the problem you have to choose the same font, but without the @.
    Active Contributor
    01-22-2013 01:04 PM in reply to: EduardoBoarati
    ABSOLUTELY CORRECT ARIAL FROM MICROSOFT  IS BUGGED,,,, USELESS, WHY THEY THIS ??  GO FIGURE.
