AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
MTEXT With Problems
- Highlight
- Email to a Friend
Hi everyone
I have an issue with the MTEXT. When I try to edit what is written inside the windows of the MTEXT, the text rotates and goes to the vertical position. Even If i change the Rotation angle to 0 on properties, when i finish editing the text it rotates again to the vertical position.
The issue is on the video.
Re: MTEXT With Problems
- Highlight
- Email to a Friend
There is something wrong with the style used. I was able to copy/paste into a new mtext box without formatting.. i used the "Standard" style, and i was able to edit it. This is a very strange bug.
- Highlight
- Email to a Friend
For some reason the font "arial unicode ms" is buggy with ACAD...in your dwg, whenever I changed the font in the same style, everything came out fine.
- Highlight
- Email to a Friend
thanks guys for your help,
If i discover that its really a bug with the arial unicode ms i'll post it here later.
Thanks again.
- Highlight
- Email to a Friend
Hi !!
I found out what was happening.
every font with the @ at the begining like "@arial black" is made to right in the vertical position.
to solve the problem you have to choose the same font, but without the @.
- Highlight
- Email to a Friend
ABSOLUTELY CORRECT ARIAL FROM MICROSOFT IS BUGGED,,,, USELESS, WHY THEY THIS ?? GO FIGURE.
