• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    Loft tool creates extra side line
    289 Views, 5 Replies
    04-08-2012 08:37 AM
    Hi everyone,
    I'm new to Autocad but trying to learn it. I'm using Autocad 2011 and trying to convert a 2D drawing into 3D using a Loft tool. However, I'm experiencing a bit of a problem. The Loft tool is creating an extra line between the two objects which messes up part of the design. I'm usind Solid and Ruled settings of the Loft tool and the two object I'm trying to join were created out of number of polylines which then were converted into singular poline using Edit Polyline tool. I cannot figure out what the problem is.
    I've attached two pdf files which hopefully will help you to see my problem.
    Thank you in advance for your help.
    Please use plain text.
    *Expert Elite*
    Re: Loft tool creates extra side line
    04-08-2012 02:00 PM in reply to: juranich
    Sorry, I even don't see the "extra line" in the amount of lines you have.
    Upload your drawing with the two polylines so we can look into the geometry.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    04-09-2012 06:00 AM in reply to: juranich
    Here I added edited pdf showing the line and I also included the dwg file so you can see it in Autocad.
    Member
    04-09-2012 06:01 AM in reply to: juranich
    Sorry, here is the dwg file.
    *Expert Elite*
    04-09-2012 07:01 AM in reply to: juranich
    AutoCAD has to find connections between the two polylines, so for every vertex in one section there has to be found the best suitable vertex in the opposite contour. And with that number of vertices (you'll see it from top view) AutoCAD has troubles to get them around the full contour sorted perfectly.
    What you should do: split your contours in regions, LOFT them and then you can UNIFY these back to one solid.
    - alfred -
    Alfred NESWADBA
    Member
    04-09-2012 03:26 PM in reply to: juranich
    Thank you Alfred, I did what you said and it worked.
    Very much appreciate your help.
