• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    sjmsme
    Lisp Routine fix for CTB files
    276 Views, 4 Replies
    01-19-2012 10:33 AM
    We work with a large number of CTB files, or at least we used to. Trying to streamline the problem. But, as a result of the way things used to be done, we have CTB files for drawings located in the folder of the drawing. Until now, this lisp routine, added to the end of the acad.lsp file, worked just fine for repathing the location autocad looks for the ctb. On my new machine, Windows 7, 64 bit with 2012, it will not work. Any ideas?
    here's the lisp routine we use:
    (defun C:GC ()
     (setq printerstylesheetdir (getvar "dwgprefix"))
      acadLocation (vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\"
       (vlax-product-key)) "AcadLocation")
     (setenv "PrinterStyleSheetDir" printerstylesheetdir)
    (princ)
    Here's the error i get now...
    Command: GC
    no function definition: VLAX-PRODUCT-KEY :error#2*Cancel*
    Help!
    Thanks!
    Shaun
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: Lisp Routine fix for CTB files
    01-19-2012 01:52 PM in reply to: sjmsme
    hi,
    here is a correction to your lisp function
    (defun C:GC ()
    		      (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key)) "AcadLocation"))
     (princ)
    cheers
    Moshe
    dgorsman
    01-19-2012 03:05 PM in reply to: sjmsme
    Odds are, you are missing a call to (vl-load-com) in your new system.  You should also verify that registry path - it might be different for 64 bit applications.  Also, there is a LISP function (gc) which you might end up conflicting with if not careful with the C: prefix.  Give it a long descriptive name and then use the PGP to shorten it up to GC or whatever works for you.
    Adopt. Adapt. Overcome. Or be overcome.
    Active Member
    sjmsme
    01-20-2012 03:53 AM in reply to: Moshe-A
    Moshe-A,
    Thanks but no cigar. Same error.
    Shaun
    Active Member
    sjmsme
    01-20-2012 03:54 AM in reply to: dgorsman
    dgorsman,
    thanks. I changed the "defun" to getctb and will change the quickkey stroke. Not too sure how to look into my registry on 64 bit.
