• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    Line weight
    290 Views, 7 Replies
    10-02-2012 05:06 AM
    Hi
    I'm experience chanllenge in editing The line in my dwg. The line weight on my drawing once printed, is not The same as I have set up on my pen setting style. I have tried The pedit function by increasing The line width to 0.6mm but nothing change on my preview window. It looks like there is an issue with reference editing. Any help guys?
    Regards
    Please use plain text.
    pendean
    Re: Line weight
    10-02-2012 05:10 AM in reply to: calembequeta
    You can't use both a plot style table setting and a Pline width setting: they cancel each other out.
    Chose one, or the other, and stick with it.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Member
    Re: Line weight
    10-02-2012 05:30 AM in reply to: pendean
    Hi Dean
    I have tried both separately but it didn't work. I usually use one pen setting style for all my drawings and it works. This specific one is not working with my pen setting or with pedit line width.
    Distinguished Mentor
    ampster
    Re: Line weight
    10-02-2012 05:34 AM in reply to: calembequeta
    try the lineweight command.  In the window that pops up, check what the option "Display Lineweight" is set to.  If it's enabled, disable it or vice versa.
    HTH
    pendean
    Re: Line weight
    10-02-2012 05:40 AM in reply to: calembequeta
    If you want, post the file and it's plot style table and let's all have a look.
    Re: Line weight
    10-03-2012 05:33 AM in reply to: calembequeta
    Changing the thickness of a polyline lets you establish its width in model units, not paper units. Setting lineweights as others have explained will affect the width in paper units if the plot style is set up to use object lineweights. Otherwise the plotstyle governs the lineweights on paper.
    Valued Contributor
    pkolarik
    Re: Line weight
    10-03-2012 06:14 AM in reply to: pendean
    This used to be the case, but upon confirming just now by trying it here you *can* use a ctb file *and* pline widths to modify your plotted lineweights
    (here's what my plot box settings look like, if that makes any difference)
    Member
    Re: Line weight
    10-03-2012 06:29 AM in reply to: pkolarik
    Thank you guys, got it right.
    Regards
