AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I'm experience chanllenge in editing The line in my dwg. The line weight on my drawing once printed, is not The same as I have set up on my pen setting style. I have tried The pedit function by increasing The line width to 0.6mm but nothing change on my preview window. It looks like there is an issue with reference editing. Any help guys?
Regards
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Dean
I have tried both separately but it didn't work. I usually use one pen setting style for all my drawings and it works. This specific one is not working with my pen setting or with pedit line width.
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
try the lineweight command. In the window that pops up, check what the option "Display Lineweight" is set to. If it's enabled, disable it or vice versa.
HTH
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Changing the thickness of a polyline lets you establish its width in model units, not paper units. Setting lineweights as others have explained will affect the width in paper units if the plot style is set up to use object lineweights. Otherwise the plotstyle governs the lineweights on paper.
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This used to be the case, but upon confirming just now by trying it here you *can* use a ctb file *and* pline widths to modify your plotted lineweights
(here's what my plot box settings look like, if that makes any difference)
Re: Line weight
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you guys, got it right.
Regards
