• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    License server and ip adress
    286 Views, 2 Replies
    09-17-2012 05:19 AM
    we have got a license server for AutoCad2010.
    We intend to change only the ipadres of this license server. The mac adress and hostname will stay the same.
    Is this possible without consequences for the clients ?
    Do we have to request for new licenses ?
    Thanks for helping out
    Rinke de Roos
    Please use plain text.
    Re: License server and ip adress
    09-18-2012 01:34 AM in reply to: RoosR
    The license files shouldn't need any changes, but you'll have to tell the clients where to ask for a license.
    In our installation the address of the server is defined in the licpath.lic file on each client, but I seem to remember there was some alternatives here. Time to dig out the documentation.
    TravisNave
    10-03-2012 10:46 AM in reply to: RoosR
    So long as your DNS is working properly, you shouldn't have any problems.  Worst case, modify the HOSTS file on each client to point to the new IP address or create an ADSKFLEX_LICENSE_FILE system environment variable that points to @IPADDRESS.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
