AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Layers question
- Highlight
- Email to a Friend
When I copy and paste with a base point an object from another file, the objects carry over the layer(s) the object is on. Now I take these objects and place them on the correct layer, already existing in the file. When I purge the file the layers will not delete. When I do a view layers, the layers that where copied and pasted still show geometry on that layer but if I turn every thing off but those layers, nothing shows on the screen. How do I handle this? Thanks
Re: Layers question
- Highlight
- Email to a Friend
Re: Layers question
- Highlight
- Email to a Friend
does the geometry you are pasting include block entities?
Re: Layers question
- Highlight
- Email to a Friend
Yep, that sounds like blocks with layers assigned to the objects inside the block.
Re: Layers question
- Highlight
- Email to a Friend
In case the previous suggestions do not help, please upload your files so that we can have a look.
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc.
Re: Layers question
- Highlight
- Email to a Friend
Did you manage to sort this one out?
Cheers,
Luciane
Re: Layers question
- Highlight
- Email to a Friend
try tying -purge and then all and see what happens.
Re: Layers question
- Highlight
- Email to a Friend
The fix I used for this. Go to Layers Properties Manager, select all, unlock, unfreeze and turn all layers on. Lock the layers you don't want, do a 'copy with base point', pick base point (0,0). When selected open another window and do 'paste as block' at 0,0 point. Check layers properties manager to see if unwanted layers are still there. When satisfied explode block and save as existing file. This cleared my problem. Thanks
