• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Layers question
    255 Views, 7 Replies
    02-29-2012 03:46 AM
    When I copy and paste with a base point an object from another file, the objects carry over the layer(s) the object is on. Now I take these objects and place them on the correct layer, already existing in the file. When I purge the file the layers will not delete. When I do a view layers, the layers that where copied and pasted still show geometry on that layer but if I turn every thing off but those layers, nothing shows on the screen. How do I handle this? Thanks
    Please use plain text.
    3wood
    Re: Layers question
    02-29-2012 04:28 AM in reply to: ut2897h
    Have you tried save the file and re-open it to see if you can purge?
    3wood
    CAD KITS
    JGerth
    Re: Layers question
    02-29-2012 04:34 AM in reply to: ut2897h
    does the geometry you are pasting include block entities?
    *Pro
    nestly
    Re: Layers question
    02-29-2012 05:17 AM in reply to: JGerth
    Yep, that sounds like blocks with layers assigned to the objects inside the block.
    Product Support
    Re: Layers question
    03-02-2012 05:58 AM in reply to: ut2897h
    In case the previous suggestions do not help, please upload your files so that we can have a look.
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Product Support
    Re: Layers question
    03-06-2012 09:26 AM in reply to: ut2897h
    Did you manage to sort this one out?
    Cheers,
    Luciane
    Active Member
    Re: Layers question
    03-06-2012 02:20 PM in reply to: ut2897h
    try tying -purge and then all and see what happens.
    Re: Layers question
    03-27-2012 06:04 AM in reply to: ut2897h
    The fix I used for this. Go to Layers Properties Manager, select all, unlock, unfreeze and turn all layers on. Lock the layers you don't want, do a 'copy with base point', pick base point (0,0). When selected open another window and do 'paste as block' at 0,0 point. Check layers properties manager to see if unwanted layers are still there. When satisfied explode block and save as existing file. This cleared my problem. Thanks
