• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Mentor
    Layer Control" display
    189 Views, 4 Replies
    01-31-2013 07:18 AM
    At the top of my screen, I have the "Layer Control".
    Until this week, if I clicked on a line, the layer the line is on is diplayed in the "Layer Control".
    If I wanted to know which layer an item is on, I just click on it and its layer would be displaye.
    If I wanted to change the layer an item is on, I just click on it, then go to the "Layer Control", scroll thru the list, click on the layer I want.
    This week, the "Layer Control" just shows the Current Layer.
    Did I change a setting?
    Read Ya Later -KLYPH
    Please use plain text.
    Patchy
    Re: Layer Control" display
    01-31-2013 07:20 AM in reply to: KLYPHY
    Maybe your PICKFIRST is set at ZERO, try 1.
    Valued Mentor
    01-31-2013 07:39 AM in reply to: Patchy
    That was it. I normally have is set to "1", but somehow it became set to "0".
    Thanks. Read Ya Later -KLYPH
    Distinguished Mentor
    braudpat
    01-31-2013 07:51 AM in reply to: KLYPHY
    Hello
    Just an idea ...
    Command: LAYER
    Then in the left part (Filters) of the Layers dialog box, please check that you are displaying ALL Layers
    Close
    Is it ok ?
    Bye, Patrice
    dgorsman
    01-31-2013 03:23 PM in reply to: KLYPHY
    Chances are you have some customization or third-party additions present with either no or very basic error handling.  When a tool is called it changes the system variable temporarily, does its work, then (if all goes well) restores the previous value.  If it errors out part way through it doesn't restore the previous setting and you're left holding the empty bag.  If you've ever had the FILEDIA issue, its the same priniciple.
    Adopt. Adapt. Overcome. Or be overcome.
