AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Layer Control" display
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
At the top of my screen, I have the "Layer Control".
Until this week, if I clicked on a line, the layer the line is on is diplayed in the "Layer Control".
If I wanted to know which layer an item is on, I just click on it and its layer would be displaye.
If I wanted to change the layer an item is on, I just click on it, then go to the "Layer Control", scroll thru the list, click on the layer I want.
This week, the "Layer Control" just shows the Current Layer.
Did I change a setting?
Read Ya Later -KLYPH
Re: Layer Control" display
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe your PICKFIRST is set at ZERO, try 1.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That was it. I normally have is set to "1", but somehow it became set to "0".
Thanks. Read Ya Later -KLYPH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
Just an idea ...
Command: LAYER
Then in the left part (Filters) of the Layers dialog box, please check that you are displaying ALL Layers
Close
Is it ok ?
Bye, Patrice
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Chances are you have some customization or third-party additions present with either no or very basic error handling. When a tool is called it changes the system variable temporarily, does its work, then (if all goes well) restores the previous value. If it errors out part way through it doesn't restore the previous setting and you're left holding the empty bag. If you've ever had the FILEDIA issue, its the same priniciple.
Adopt. Adapt. Overcome. Or be overcome.
