• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    jz4all
    Kann't make new workspace?
    134 Views, 5 Replies
    06-21-2012 02:47 AM
    I tried to make new workspace but it did not work.
    See the attachement. That what I got every time I try.
    thanks
    Please use plain text.
    Re: Kann't make new workspace?
    06-21-2012 03:41 AM in reply to: jz4all
    how did you create this file? We are in the AutoCAD 2010 forum and the file in the screenshot looks like from version 2012!
    - alfred -
    Alfred NESWADBA
    jz4all
    06-21-2012 04:22 AM in reply to: alfred.neswadba
    hi
    I have AUtoCad ver. 2010. I was on vacation when my colleague used my PC. maybe he used a drawing produced in upper version. Hij is on vacation now.
    How can I solve this?
    pendean
    06-21-2012 05:43 AM in reply to: jz4all
    You may be using 2010, but someone loaded a 2012 CUIx menu file and 2010 cannot write or edit that menu (just like the error message indicates).
    CUIUNLOAD command and remove that menu file listed on the error message is a good start: or better yet, if you are fully backed up, restore your old menu back.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    jz4all
    06-22-2012 02:28 AM in reply to: pendean
    I copied CUIX 2010 from a colleague. I loaded it without deleting the CUIX 2012 from menu's file. But the problem still exist. I don't know if there are consequences if I delete CUIX 2012.
    jz4all
    06-22-2012 03:48 AM in reply to: jz4all
    Thanks everybody.
    I solved it.
    My a.cad file is deleted for some reasons and changed !!! fortunately, I have a reserve copy and I turned it back as it was before.
